Manual Chapter : Working with OpenAPI
Applies To:
  • BIG-IP ASM
    16.0.1, 16.0.0, 15.1.0, 15.0.1, 15.0.0
You can use your existing OpenAPI (Swagger) specification file to quickly create an Application Security Manager security policy. Use the REST API to upload the specification file. When creating the security policy in the GUI, use the special API Security policy template. This streamlined template and the configurations contained in your OpenAPI specification file eliminate the need for further regular security policy configurations in ASM.
Note: There is no support for OpenAPI file upload when sent with multipart/form-data.
OpenAPI / ASM integration is useful in a CI/CD environment. Using a CI/CD pipeline, the security policy can be regularly and automatically updated.
When using an API Security policy, regular traffic learning is disabled because the expected traffic configurations are already defined in the OpenAPI specification file. However, learning is enabled for the following violation groups:
  • HTTP protocol compliance
  • Evaluation techniques
  • Disallowed file types
  • Attack signatures
  • Meta characters
When an updated OpenAPI specification file is uploaded, all previous entities not in the updated file are erased from ASM with the exception of signatures and meta characters.
Note: The basePath is used as the API gateway. Therefore, the basePath/path must be configured for the actual server where the API will be deployed. An incorrect basePath will prevent traffic from being routed to ASM.
