Manual Chapter : Creating a bidirectional IPsec traffic selector for dynamic template
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 17.1.0
BIG-IP Link Controller
  • 17.1.0
BIG-IP LTM
  • 17.1.0
BIG-IP AFM
  • 17.1.0
BIG-IP ASM
  • 17.1.0
Manual Chapter
The traffic selector you create filters traffic based on the IP addresses and port numbers that you specify, as well as the custom IPsec policy you assign.
  1. On the Main tab, click
    Network
    IPsec
    Traffic Selectors
  2. Click
    Create
    The New Traffic Selector screen opens.
  3. In the
    Name
    field, type a unique name for the traffic selector.
  4. In the
    Description
    field, type a brief description of the traffic selector.
  5. For the
    Order
    setting, retain the default value (
    First
    This setting specifies the order in which the traffic selector appears on the Traffic Selector List screen.
  6. From the
    Configuration
    list, select
    Advanced
  7. For the
    Source IP Address
    setting, click
    Host
    or
    Network
    , and in the
    Address
    field, type an IP address.
    This IP address should be the host or network address from which the application traffic originates.
    This table shows sample source IP addresses for Router in site B.
    System Name
    Source IP Address
    Router in site B
    4.4.4.0/24
  8. From the
    Source Port
    list, select the source port for which you want to filter traffic, or retain the default value
    *All Ports
  9. For the
    Destination IP Address
    setting, click
    Host
    , and in the
    Address
    This IP address should be the final host or network address to which the application traffic is destined.
    This table shows sample destination IP addresses for any device in site A.
    System Name
    Device in Site A
    192.0.2.13
  10. From the
    Destination Port
    list, select the destination port for which you want to filter traffic, or retain the default value
    * All Ports
  11. From the
    Protocol
    list, select the protocol for which you want to filter traffic.
    You can select
    * All Protocols
    TCP
    UDP
    ICMP
    , or
    Other
    . If you select
    Other
    , you must type a protocol name.
  12. From the
    Direction
    list, select
    Both
  13. From the
    Action
    list, select
    Protect
    The
    IPsec Policy Name
    setting appears.
  14. From the
    IPsec Policy Name
    list, select the name of the custom IPsec policy that you created.
  15. Click
    Finished
    The screen refreshes and displays the new IPsec traffic selector in the list.
