Updated Date: 07/07/2026
DC1 BIG-IP routing analysis
This discussion examines the routing table for the BIG-IP devices in data center 1 (DC1). The discussion references diagrams and tables that you can link to below.
- For references to DC1, refer to Data center 1 routing diagram and table.
- For references to DC2, refer to Data center 2 routing diagram and table.
Note: A quick look at either of the routing tables reveals that a number of the routes needed for the system illustrated in the corresponding routing diagram are not included in the table. That’s because devices that are on the same subnet do not need a static route.
- eth0 to DC1 BIG-IP devices on the Discovery subnet
- The entry for this route is in cell A23. The static route goes from the eth0 NIC in DC1 to the discovery subnet in DC1. It is specified in the table as: 10.1.1.0 255.255.255.0 10.4.4.254
- The first octet 10.1.1.0 specifies the destination IP address used to communicate with the Discovery subnet in DC1.
- The next octet 255.255.255.0 specifies the network mask for this subnet.
- The last octet, 10.0.0.254 is the gateway for this subnet.
This route uses the Discovery subnet to go from BIG-IQ CM and DCD devices in DC1 to the BIG-IP devices in DC1. As the subnet name implies this route is mostly used for discovery, but also plays a role in disaster recovery scenarios.
- eth0 to DC2 BIG-IP devices on the Discovery subnet
- The entry for this route is in cell A24. The static route goes from the eth0 NIC in DC1 to the discovery subnet in DC2. It is specified in the table as: 10.101.101.0 255.255.255.0 10.4.4.254
- The first octet 10.101.101.0 specifies the destination IP address used to communicate with the Discovery subnet in DC2.
- The last octet, 10.4.4.254 is the gateway for this subnet.
This route uses the Discovery subnet to go from BIG-IQ BIG-IP devices in DC1 to the BIG-IP devices in DC2. As the subnet name implies this route is mostly used for discovery, but also plays a role in disaster recovery scenarios.
- eth3 interface to DC2 DCDs on the Listener subnet
- The entry for this route is in cell A26. The static route for the eth3 NIC is 10.103.103.0 255.255.255.0 10.5.5.254.
- The first octet 10.103.103.0 specifies the destination IP address used to communicate with the cluster subnet in DC2.
- The last octet, 10.3.3.254 is the gateway for this subnet.
This route uses the Listener subnet to go from BIG-IP devices in DC1 to the DCDs in DC2. BIG-IP devices in DC1 use this route to communicate event, alert, and performance analytics data to DCDs in DC2. This route also plays a role in disaster recovery scenarios.
- eth3 interface to DC1 DCDs on the Listener subnet
- The entry for this route is in cell A27. The static route for the eth3 NIC is 10.3.3.0 255.255.255.0 10.5.5.254.
- The first octet 10.3.3.0 specifies the destination IP address used to communicate with the cluster subnet in DC1.
- The last octet, 10.5.5.254 is the gateway for this subnet.
This route uses the Listener subnet to go from BIG-IP devices in DC1 to the DCDs in DC1. BIG-IP devices in DC1 use this route to communicate event, alert, and performance analytics data to DCDs in DC1. This route also plays a role in disaster recovery scenarios.
