Manual Chapter : F5 Access Apps
Applies To:
  • BIG-IP APM
    15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0
F5 Access Apps
F5 Access for Android, F5 Access for iOS, and F5 Access for Chrome OS enable secure network access for supported mobile clients. Previously, the Android and iOS products were called BIG-IP® Edge Client® for Android and BIG-IP Edge Client for iOS. For the clients to connect, you need a Network Access configuration on BIG-IP Access Policy Manager®. The Network Access Wizard creates a Network Access configuration with authentication, an access policy, and a virtual server with connectivity and access profiles.
You might need to update the connectivity profile or the network access resource to complete the configuration on APM®. Optionally, you can also configure SSO and ACLs, and add items to the access policy to enable SSO and enforce ACLs.
  1. Running the Network Access Setup wizard
  2. Configuring a connectivity profile for F5 Access for iOS
  3. Configuring a connectivity profile for F5 Access for Android
Your DNS server must be configured to resolve internal addresses with DNS.
Configure Access Policy Manager to provide users with full network access when they use BIG-IP Edge Client for iOS or BIG-IP Edge Client for Android.
Important: You must specify either the DNS Default Domain Suffix or the DNS Address Space in the Network Access configuration. Otherwise, the system cannot resolve internal DNS addresses.
  1. On the Main tab, click Wizards > Device Wizards.
    The Device Wizards screen opens.
  2. Select Network Access Setup Wizard for Remote Access, and then click Next.
    Tip: Follow the instructions in the wizard to create your access policy and virtual server.
  3. To ensure that Edge Apps can connect from supported mobile devices, for Client Side Checks, clear the Enable Antivirus Check in Access Policy check box.
  4. To specify the DNS Address Space setting, on the Network Access screen perform these substeps:
    1. From Traffic Options, select Force Use split tunneling for traffic.
      Additional settings display.
    2. In the DNS Address Space setting, for each address space, type the address in the form site.siterequest.com or *.siterequest.com , and click Add.
  5. On the DNS Hosts screen, you can type a value in the DNS Default Domain Suffix field.
  6. After you complete the wizard screens and create the configuration, on the Setup Summary screen click Finished.
You now have a network access configuration that supports BIG-IP Edge Client for mobile devices. All configuration object names are prefixed with the policy name that you entered in the wizard.
A connectivity profile automatically contains default settings for F5 Access for iOS. You should configure the connectivity profile settings to fit your situation.
  1. On the Main tab, click Access > Connectivity / VPN > Connectivity > Profiles.
    A list of connectivity profiles displays.
  2. Select the connectivity profile that you want to update and click Edit Profile.
    The Edit Connectivity Profile popup screen opens and displays General Settings.
  3. From Mobile Client Settings in the left pane, select iOS Edge Client.
    Settings for the iOS Edge Client display in the right pane.
  4. To enable users to save their passwords for reconnection purposes within a specified time period, select the Allow Password Caching check box.
    The additional fields in the area become available.
  5. To enable device authentication on the client, select Require Device Authentication.
  6. For Save Password Method, specify how to perform password caching:
    • To allow the user to save the encrypted password on the device without a time limit, select disk.
    • To specify that the user password is cached in the application on the user’s device for a configurable period of time, select memory. If you select memory, the Password Cache Expiration (minutes) field becomes available.
  7. If the Password Cache Expiration (minutes) field displays, type the number of minutes you want the password to be cached in memory.
  8. In the On Demand Disconnect Timeout (minutes) field, retain the default 2, or type a different number of minutes before VPN on demand times out.
  9. To force the app to use a selected logon mode and prevent users from changing it:
    1. Select the Enforce Logon Mode check box.
    2. From the Logon Method list, select web or native.
    Note: This feature is supported with F5 Access for iOS and F5 Access for Android.
  10. Click OK.
    The popup screen closes, and the Connectivity Profile List displays.
You have now configured the security settings for BIG-IP Edge Client for iOS.
To provide functionality with a connectivity profile, you must add the connectivity profile and an access profile to a virtual server.
A connectivity profile automatically contains settings for F5 Access for Android. You should configure the settings to fit your situation.
  3. From Mobile Client Settings in the left pane, select Android Edge Client.
    Settings for the Android Edge Client display in the right pane.
  5. For Save Password Method, specify how to perform password caching:
  6. If the Password Cache Expiration (minutes) field displays, type the number of minutes you want the password to be cached in memory.
  7. To enhance security on the client, retain the selection of the Enforce Device Lock check box (or clear the check box).
    This check box is selected by default. Edge Portal and Edge Client support password locking, but do not support pattern locking. If you clear this check box, the remaining settings in the area become unavailable.
  8. For Device Lock Method, retain the default numeric, or select a different method from the list.
  9. For Minimum Passcode Length, retain the default 4, or type a different passcode length.
  10. For Maximum Inactivity Time (minutes), retain the default 5, or type a different number of minutes.
  11. To force the app to use a selected logon mode and prevent users from changing it:
  12. Click OK.
You have now configured the security settings for BIG-IP Edge Client for Android.
