Applies To:
BIG-IQ Centralized Management
8.4.0, 8.3.0, 8.2.0, 8.1.0, 8.0.0
Monitoring application service host devices
Application service device charts
This table describes the menu options and charts found in the application service dashboard (Applications > APPLICATIONS > <Application Name> > <Application Service>). Select the option marked in the image to view charts at the bottom of the screen. These charts display the trends of the host BIG-IP device, or service scaling group. Each chart displays an aspect of the devices as a function of the selected time period. -
Device health metrics
The following list defines metrics sets and their corresponding metrics for the application statistics displayed in the dimensions pane table in the Device Health screen of the GUI. Each table row is read from left to right, where each metric set is defined as it would relate to each listed dimension, and each metric corresponds to its metric set. -
Device traffic metrics
The following list defines metrics sets and their corresponding metrics for the application statistics displayed in the dimensions pane table in the Device Traffic screen of the GUI. Each table row is read from left to right, where each metric set is defined as it would relate to each listed dimension, and each metric corresponds to its metric set. -
Device health alerts
The device health alert notifies you of changes in device resource and throughput metric thresholds for your BIG-IP devices. To view your device health thresholds, go to the Alert Rules screen and select the default device rules (Applications > ALERT MANAGEMENT > Alert Rules.
