Applies To:
BIG-IQ Centralized Management
8.4.0, 8.3.0, 8.2.0, 8.1.0, 8.0.0
Monitoring TCP application service data
TCP Charts
The charts that reflect TCP data allow you to analyze current traffic data, and troubleshoot any issues that may occur over time. The parameters found in the charts described can indicate the wait time over the course of the client-server communication channel. To view charts for a TCP application service, go to Applications > APPLICATIONS > <Application_Name> > <TCP_Application_Service>. -
TCP Dimensions and Metrics
The following list defines the metrics gathered to monitor TCP network connections and the dimension aspects from which data is observed. The information provided is found in the dimensions pane tables with the screens that display TCP data. You use this information to filter the on-screen data by specific dimension objects. For example, if you would like to view data that pertains to specific virtual servers. It is important note that all metric data is displayed as a unit over the time period selected for the screen.
