Manual Chapter :
NATs for inbound connections
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
With respect to NATs, an
inbound
connection is a connection that is initiated by a
node on an external network, and comes into the BIG-IP® system to a node
on the internal network.Without a NAT
Normally, traffic coming into the BIG-IP system is load balanced to a server in a pool, based on the load balancing method configured for that pool, in the following way:
- A client on an external network typically sends traffic to a virtual server on the BIG-IP system. The destination IP address in this case is the virtual server address.
- Upon receiving a packet, the virtual server typically translates that destination IP address to the IP address of a pool member, for the purpose of load balancing that packet.
- The pool member then sends its response back through the BIG-IP system, using a route specified in the server node’s routing table (ideally, a floating IP address assigned to an internal VLAN). On receiving the response, Local Traffic Manager then performs the reverse translation; that is, the system translates the pool member’s actual source address to the virtual server address. This results in the source address in the response to the client being the virtual server address, which is the source address that the client expects to see.
This typical load balancing scenario ensures that for load balanced traffic, the client system never sees the internal private class IP address of an internal node.
With a NAT
If the client system wants to bypass the load balancing mechanism to send packets directly to a specific node on the internal network, the client needs a routable IP address to use to send packets to that server node.
A NAT solves this problem by providing a routable address that a client can use to make a request to an internal server directly. In this way, a NAT performs the same type of address translation that a virtual server performs when load balancing connections to pool members. In the case of a NAT, however, no load balancing occurs, because the client is sending a request to a specific node. The NAT translates the public destination IP address in the request to the private class IP address of the internal node.
When the server node sends the response, Local Traffic Manager performs the reverse translation, in the same way that a virtual server behaves.
Local Traffic Manager does not track NAT connections. Therefore, the public IP address that you define in a NAT cannot be the same address as a virtual address or SNAT address.
For example, suppose a node on the internal network (such as a load balancing server) has a private class IP
address of
172.16.20.3
. You can create a NAT designed to translate a
public destination address of your choice (such as 207.10.1.103
) to the
private class address 172.16.20.3
. Consequently, whenever a node on the
external network initiates a connection to the address 207.10.1.103
Local Traffic Manager translates that public destination address to the private class address
172.16.20.3
.Sample NAT for an inbound connection
In this example, the NAT provides a routable address for an external node to initiate a connection to an internal node.
When you create a NAT, you must define two settings: NAT Address and Origin Address. In our
example:
- The NAT address is207.10.1.103, and the origin address is172.16.20.3.
- The connection is an inbound connection, meaning that the connection is being initiated from the external network, through the BIG-IP system, to the internal network.
- Local Traffic Manager translates the NAT address to the origin address.
- The NAT address and the origin address are destination addresses.
